Coil on Plug?
Old Apr 11, 2010 | 09:50 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Coil on Plug?
Do they make any coil on plugs for the V8 TBI setup? If so are they worth it?
Old Apr 12, 2010 | 06:02 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Coil on Plug?
No
A coil per cyl system is available for port injection setups though. Read the stickys in the TPI forum
Old Apr 12, 2010 | 10:34 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Coil on Plug?
I have a 305 TBI, i was just curious on them.. if its not compatible then i should have no interest, correct?
Old Apr 12, 2010 | 11:19 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Coil on Plug?
With the required harness, upgrading to port injection is simply a manifold swap. Use whatever you like
Its not compatible with the actual TBI unit itself. It doesnt mean you cant swap the newer control system into your car
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
