HELP!!! Wiring up relays
Old Apr 13, 2010 | 05:58 PM
CanaryYellowZ28's Avatar
Car: 85 Z28 99 Z28
Engine: 350 LS1
Transmission: 700r4 4L60E
Hey guys, I have an 85 Camaro Z28 and I'm trying to wire up some new relays. I have all the wires run and I'm trying to hook up the low beam relay and I can seem to figure out which wire the trigger should go to. I have the high beam relay on a light green wire and it says there is a brown wire i'm supposed to connect it to and I tried that but it didnt work. I'm wondering if there is another location that I need to look for that comes from the dimmer switch but I have no idea where to start. Any help would be appreciated
Old Apr 14, 2010 | 05:54 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: HELP!!! Wiring up relays
Are you using the headlight connector as your trigger line, or going all the way back to the switch?
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
