fusable links???????
Old Apr 14, 2010 | 08:54 PM
racerquinny's Avatar
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
i got a 91 camaro RS 305tbi automatic
can anyone explain the fusable links on the passenger side radiator support. where they go.
also would help how to fix one...i believe i got coolant into one and corroded it. so the resistance is way up. my problem is that i have no fuel or spark whats so ever. ive checked back to coil and nothing.
i replaced
-distributor
-module
-cap
-rotor
-wires
-coil
-plugs
basically all the ignition components except for ign lock cylinder, but i doubt that will be it. pcm is good, recently replaced that as well. also when car is in Key on engine off....the engine light comes on. that i believe indicates there is signal from the pcm.
pelase help me, im stumped. last resort is this fusable link. id feel so dumb if it was.
on the plus side i have all new ign components.
Old Apr 15, 2010 | 02:04 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Missing Link
Are you getting 12 volts at the coil primary?
Happy Racing!
I Didn’t Wreck, The Track Moved
Old Apr 15, 2010 | 02:17 PM
1986maro's Avatar
Car: 86 Camaro Iroc-z
Engine: Lb9 (305 TPI)
Transmission: 700r4w/ 2500 stall shift kit
Axle/Gears: quick performance ford 9 3:70
Re: Missing Link
i would test each side with a test light and see if you have power.
the fueslinks by your rad might be for tha fan but im not sure
Old Apr 16, 2010 | 03:49 AM
Re: Missing Link
alls i know, is the one if for a fan...not sure what the other 3or4 do.
Old Apr 17, 2010 | 06:19 PM
Re: Missing Link
the camaro is fixed...my dad bumped a wire above the brake booster when i had it key on engine off. and the fan started. so i tried starting it. and boom i had fuel and spark, then it started right up.
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
