305 H.O. won't fire
Old Apr 15, 2010 | 10:33 PM
3oh3 Cruiser's Avatar
305 H.O. won't fire
Drove the car on Monday, went to start it on Tuesday night and the car would turn but wouldn't fire. Today, replaced the ignition module, ignition coil, spark plug wires, distributor cap and rotor, and there is NO spark whatsoever. Thinking it's the distributor itself, but I want some more opinions.
Any thoughts? I'd really appreciate it!
Old Apr 15, 2010 | 10:51 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: 305 H.O. won't fire
Carb? what year?
Old Apr 15, 2010 | 10:54 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
well if there is juice at the coil + wire, then the only other thing would be the pickup coil inside the distributor... the distributor would have to come out... are you sure there is no spark? How did you verify this?
Old Apr 16, 2010 | 10:29 AM
1985 Camaro IROC-Z with a 305 H.O. 4-barrel carb.
We tested a couple of the boots at the spark plugs with an electrical probe, you know place the tip where there should be power and it lights up sort of deal.
Old Apr 16, 2010 | 11:48 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
the way to check for spark if you don't have a spark tool, is you put the end of a flat head screwdriver into a spark plug wire and then set the screwdriver about an inch or so from ground and have someone crank it, you should see a nice bright spark jump to ground....
Old Apr 17, 2010 | 12:17 PM
Fixed it. The ECM wasn't getting any power and as a result, no spark. Thanks for input though!
Derick15
Sep 17, 2016 05:28 PM
I'llrocya
Feb 2, 2016 11:43 PM
LittleFranks
Sep 17, 2015 12:22 PM
theurge
Aug 21, 2015 12:46 PM
justin57
Aug 20, 2015 07:05 PM
