ecm fuse blowing
ecm fuse blowing
hey guys sorry im bad with wiring problems so maybe you can help me out. My ecm fuse keeps on blowing. i pulled the fuse panel down some and saw it was a pink and black wire. But it heads up towards the guages. does anyone have a ecm wireing diagram or what it does. It is a 1985 carberated 305 motor. i just installed a electronic tac and t56 transmission but i dont see why that would do anything. the car lost alot of power and has rough takeoffs now. please any help would be great.
Dave
Dave
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuse Abuse
Disconnect the ECM.
Install new fuse.
Does the ECM fuse still blow?
Happy Racing!
Spin Me This Week … I’ll Spin You Next Week
Install new fuse.
Happy Racing!
Re: ecm fuse blowing
well i disconnected the ecm replaced the fuse and then reconected the ecu and started it up and the fuse was good after i shut it down and looked at it. Then i took it for a ten minute drive and shut it down and checked it and it was blown again. any ideas? Is there an electronic spark control module on the 1985 carburated model? I know theres one for tpi but i cant find a diagram for my car.
thnk you and any ideas whatsoever will help
Dave
Dave
Transmission: 765R4
Fuse Abuse
You want to find out what part of the circuit is blowing the fuse.
Put 5 amp fuses in line with the ECM, ESC, and the key decoder.
Leave the 10 amp fuse in it’s place.
Now when a fuse blows, you have reduced the area you need to troubleshoot to a fraction.
Happy Racing!
I Didn’t Wreck, The Track Moved
Happy Racing!
2012sergen11
Oct 13, 2015 07:38 PM
