Alternator draining battery?
Old Apr 25, 2010 | 06:44 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
Quick question, I have been having a battery drain issue that usually kills the battery within 4-5 days. I was told by a friend that the internals in an alternator can go bad and drain the bat. I told him that I had the alternator tested and it checked out fine but he said that it would still check out fine and the only way to know is to disconnect the alternator hot wire and see if the battery still drains. Has anyone heard of or experienced this kind of situation before?
Old Apr 25, 2010 | 07:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Alternator draining battery?
Have you checked the fuel pump to see if it's running constantly? The oil pressure sending unit can go bad and make the fuel pump run all the time, regardless of the key - and that will drain the battery in about 4 days.
Old May 3, 2010 | 03:19 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Did you find your problem?
Old May 3, 2010 | 08:59 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
I did find the source of my battery drain, and it was easier than I thought it would be. Turns out the rear view mirror courtesy lights were burnt out on both sides... the switch to turn them on and off was in the constant on position. I only found this out after I decided to replace any burned out bulbs I could find on the car just to eliminate any possibilities, and sure enough that was it.
Old May 3, 2010 | 09:46 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Old May 3, 2010 | 10:34 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Old May 3, 2010 | 11:30 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Really doesn't make much sense. If the bulbs weren't there to draw current, then the switch position shouldn't matter. That's why the 2 guys before me are scratching their heads.
Old May 5, 2010 | 01:01 PM
welchk85's Avatar
Car: 1990 camaro rs 3.1 v6
Engine: 3.1 v6
i had the same problem and found out that the pressure switch for the over head light on the passenger side door was not working properly and was staying on all the time btu the bulb was dead and i fixed that and havent had the problem since. im not sure why it does it but even with a dead bulb its still sending power to it.
Old May 5, 2010 | 01:50 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
if a bulb is burnt it creats and open in the circuit, no current can flow its the same as having a switch in the circuit in the on position, basic electrical theory. The burnt out bulbs were not the source of ur parasitic drain.
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
