removing wiring
Car: 87RS/70 novaSS/85 Z28
Engine: 2.8L/468 HP unknown/HO305
Transmission: 700r4,T400,stock
Axle/Gears: stock,fab9,stock
removing wiring
I have a 85 Z-28 and want to remove wiring I dont need in the engine area. Does any one know. I went to an HEI dist and carb'd it. Any help or info would be cool. Thanks
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: removing wiring
Okay that did me no good I have removed the computer and need to know what to do with the 3 wires coming from tranny.
Re: removing wiring
They get removed
Lockup was originally controlled the ECM that you junked. You need a vacuum lockup switch now. Check out a JY for an original carb car or go to BTO for an aftermarket kit
