Another Temp Gauge Help..
Old Apr 26, 2010 | 12:47 AM
nezzie09's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
Hey guys, I've read, and read, but I'm still a little bit unclear. I have a 1987 Camaro Sport Coupe 2.8l with idiot lights. I want to add a water temp gauge and have a couple questions.
1: is this the sending unit i need? - http://www.summitracing.com/parts/SMP-TS76/
2: once i buy that, all i need is any aftermarket electric gauge?
3: how do i hook up my gauge? ..does it have one wire that goes straight to the sending unit, and one that goes to ground and that's it?
also, if i were to want to keep the idiot light AND a proper gauge, could the new sending unit be fit on a cooling hose or something?
if im missing anything please let me know.
Old Apr 26, 2010 | 03:08 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Sending Information
Yes that’s the correct sender.
Not necessarily. You must either get an aftermarket gage which states it’s compatible with stock senders, or use a sender from the aftermarket company.
First you should choose the gage you want, then read the instructions to find out if it requires a sender from the aftermarket company or if it’s compatible with stock senders.
Most of them are like that, plus an illumination/power wire.
You don’t want it in the hose. You want a circuit to light a warning lamp, and have that circuit controlled by the one new sender.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Apr 27, 2010 | 04:59 AM
nezzie09's Avatar
Engine: 2.8 MPFI
Re: Sending Information
Happy Racing!
Thanks a lot!
Old Apr 27, 2010 | 07:07 PM
nezzie09's Avatar
Engine: 2.8 MPFI
http://www.glowshiftdirect.com/Tinte...ure-gauge.aspx
this is the one I want. It comes with a sending unit with a "1/8th npt male thread".
Will that work?
Old Apr 28, 2010 | 09:28 AM
NINÅ's Avatar
Transmission: 765R4
Sending Information
You’ll need an adaptor.
1/8th female to 3/8th male NPT.
Happy Racing!
Make Noise, Turn Left, Repeat
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
