Is this correct fuel realy/fans
Old Apr 26, 2010 | 02:43 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
I have the holley dominator ecu and I it can control the fuel pump and two fans. So I think what needs to be done is run the fuel pump wire from the ecu to the gray wire on the fuel pump relay, and run the fan wires from the ecu to the dk green/white wire for the primary fan and the gray wire for the secondary fan relays. Is this correct? If not can you point me in the right direction. Appreciate it thanks
Old Apr 30, 2010 | 04:37 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Is this correct fuel realy/fans
You're on the right track
GM ECMs ground the fan relays and send 12v to the fuel relay to engage them
For 90-92 cars, gry is the relay output to pump wire. Dont mess with it. Dk grn/wht is call for both fuel and fan, just remember one grounds and one energizes to engage. I have no idea if the Holley system operates on the same relay concepts as GM, but Id assume so. GM seems to be the base for aftermarket esp for GM platforms
Related diagrams
http://www.austinthirdgen.org/mkport...ta_sensors.jpg
http://www.austinthirdgen.org/mkport...an_V6_vinT.jpg
I would suggest running independent fan relays instead of the factory dual fan control. Substitute the Holley fan pins instead of the LTx/LSx pins
http://i150.photobucket.com/albums/s...FanControl.gif
Old May 1, 2010 | 08:46 AM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Thank you, I appreciate the reply.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
mustangman65_79
Apr 14, 2017 05:37 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
