tach reads to high after engine swap
Old Apr 27, 2010 | 08:59 AM
slayernut's Avatar
Car: 92 rs camaro
Engine: 350 tbi
Transmission: 350 turbo with kit
Hi, I recently did a 3.1 conversion to 350tbi in a 92 rs and now my tach reads too high. I am wondering if there is a way to switch the tach to read 8 cylinder? I have to remove the cluster already to replace some bulbs. I am currently running an aftermarket tach but would still like to have the original reading correctly. Thanks for any info
Old Apr 27, 2010 | 03:21 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Swap Shop
There is circuitry in the dash near the tach.
It’s contained on a small plug-in PCB or integrated in the main board.
On the PCB you’ll see a resistor chip.
Desolder pins 4 & 10.
Use a 500K potentiometer.
Solder it across traces 4 & 10.
Move the potentiometer to half way.
Start the engine and compare the tach reading with a test equipment quality tach.
Dial it in, unsolder the potentiometer, measure it and install a matching resistor.
Happy Racing!
Make Noise, Turn Left, Repeat
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
