previous owner cut wiring to wiper motor
Old Apr 30, 2010 | 02:31 AM
tenholewheels's Avatar
hi fellas, i have a problem.
previous owner of my 83 z28 cut all the wiring to the wiper motor
and just about everything else.
i have a motor and the wiring harnesses but i need to know where
the wiring starts so i can start wiring the motor back.
i can't drive her without it because mississippi has an inspection
and they won't give me a sticker without the wipers working.
so if can please help.
if there is anyone that is near me and can help getting these to
work i'll buy em a case of beer.
thanks wayne
Old Apr 30, 2010 | 04:22 PM
Pocket's Avatar
Car: 91 Trans Am
Re: previous owner cut wiring to wiper motor
http://www.austinthirdgen.org/mkport..._continued.gif
Not much info available for earlier cars, sorry this is the best i could find
Old May 3, 2010 | 03:48 PM
wilmil's Avatar
Car: 83 Pontiac Trans AM
Engine: 305 CFI
I have a similar problem. The 83 TA I own had a fire and melted the connector to the wiper motor and washer pump. I bought a chilton's manual and it gives me the colors of the wires. It just doesn't say which connectors on the motor and washer pump go where. Was hoping to find a new/like new connector instead of hitting the junk yards.
Old May 15, 2010 | 10:25 PM
graywolfman's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305cid 4BBL E4ME Quadrajet
Hey fellas. Do you know if you have the multiplex wipers or the two-speed? (Multiplex is pulse-delay and 2 speed is just that.. high and low)? I have an original Pontiac shop service manual for '83 so I can probably help
Old May 16, 2010 | 11:02 AM
wilmil's Avatar
Engine: 305 CFI
I have the pulse wipers. My chilton's gives me the colors, but not the location on the connector. Hopefully even a good pic will do.
Old May 16, 2010 | 01:12 PM
Cool. I have an '83 as well, if that's all you need I will post the info for you tonight after I am off work. The only possible difference will be if you still have the old piston-type washer pump. Mine is a new version that is an electric pump, so two red wires are connected to each other instead of on the wiper motor/washer pump. Like I said, though, I'll post the info and pics tonight
Edit: Fixed an error
eightsixseven
Dec 16, 2024 01:50 PM
NinjaNife
Aug 23, 2015 11:49 AM
LittleFranks
Aug 20, 2015 03:55 PM
ZsTransAm
Aug 11, 2015 07:30 PM
slade5612
Aug 11, 2015 07:19 PM
