t/a electrical issue
Old May 1, 2010 | 12:19 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
when I hit the brakes in my friends 87 T/A the dash lights light up and the turn signal indicators light up, anyone else see this as a problem?
Old May 1, 2010 | 05:06 PM
Chevy8588's Avatar
Re: t/a electrical issue
no one has seen this one?
Old May 1, 2010 | 08:14 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
its definitely a problem. i see a lot of electrical tracing in your future. my only guess is that somehow the lights where wired into the brake lights.
Old May 1, 2010 | 08:59 PM
Chevy8588's Avatar
odd part is, no stop or tail lights, but also neither do the headlights nor parking lights come on with the pedal
Old May 4, 2010 | 01:40 AM
Chevy8588's Avatar
bump?
Old May 4, 2010 | 03:13 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
I'm sorry... I don't mean to laugh, but each time I read your original post, it makes me imagine how comical this situation must be, and I lol. It's kind of like thinking about an old slap-stick routine where one thing goes wrong, then another, and so-on, each time leaving the subject more and more confused and annoyed, wondering what's going to happen next lol.
I had a friend whose horn would honk everytime he rotated the steering wheel to turn a corner, which was hilarious lol... but hey, you always knew when he was turning into the driveway!
But moving on... I don't think there's an easy answer for you, other than you tracing wires from sources to the fuse box, then the fuse box to switches, etc., seeing what's still connected correctly and what's been jury-rigged by past owners, and then putting it all back together the way it's supposed to be. That's basically what travis was saying too, I think.
I went through this very thing with an '89 'vert I bought in 2007. Wow, what a mess its wiring was. I spent more time fixing wiring than I did driving the car.
Parking lights, taillights and the dash lights all run off the 'tail' fuse, but dash lights have their own circuit 'inst lp' that runs through the 'tail' circuit, so all of those work in conjunction with each other.
But brake lights have a fused circuit of their own.
So it sounds like the wires that were supposed to go to the 'tail' circuit have been mistakenly connected to the 'brake' circuit.
I wish there was an easier solution for you, but I don't think there is. So just start checking fuses and running wires until you get things sorted out. Good luck... and get some knee pads.
Old May 4, 2010 | 03:18 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Is the wiring original to the car? Original to the year // model?
Our Camaro did that. After a bottle of Tylenol, I found TGO. I posted my first thread about it.
( edit )
Not in any way saying this is the answer-very similar symptoms!!!
https://www.thirdgen.org/forums/elec...en-brakes.html
Frozer!!!
Jan 19, 2024 04:55 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
