fusible link between bat and alt?
Old May 2, 2010 | 12:05 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i've got a 5.7 tpi car, 87 gta, and neither one of my alternators is giving any charge when installed in the car but they test on a bench fine. are there fusible links or fuses between the battery and alternator? anything else that could cause the alternator not to give any charge, outside of the alternator itself?
edit - its a single alternator configuration, i just have two alternators, and neither works when installed in the car.
Old May 2, 2010 | 12:57 AM
1meanGTA's Avatar
Re: fusible link between bat and alt?
i think i've found the info i need from some searching... going to take a look at the car tomorrow.
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
