Disconnected cruise control,Can this damage my car
Old May 2, 2010 | 11:55 AM
joekaz1070's Avatar
Car: 1987 Trans am
Axle/Gears: GM 10 bolt
I Disconnected my cruise wiring and removed the switch at the brake pedal. Can tihs cause any problems to the car.
Old May 2, 2010 | 04:42 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: Disconnected cruise control,Can this damage my car
I don't think so, it's a seperate accessory harness. I drove my car with non of the cruise control things plugged, it ran fine.
Old May 2, 2010 | 04:54 PM
joekaz1070's Avatar
Car: 1987 Trans am
THANKS!
Old May 2, 2010 | 05:10 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I Took everything to do with cruise control out, and no problems here either.
Old May 2, 2010 | 06:29 PM
joekaz1070's Avatar
Car: 1987 Trans am
THANKS!
Old May 3, 2010 | 04:41 PM
Pocket's Avatar
Car: 91 Trans Am
Put the brake switch back in and plug it up or your TCC will be in-op. The cruise plug is on the tail light switch while the cruise vacuum plunger is on the TCC switch
Not sure why GM did it that way, but its how it is
http://www.austinthirdgen.org/mkport...se_control.jpg
http://www.austinthirdgen.org/mkport...8_vinE_TCC.jpg
http://www.austinthirdgen.org/mkport...ithout_T61.jpg
Ghettobird52
Jul 5, 2024 11:18 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
colton_carlson
Mar 8, 2019 12:21 PM
TheExaminer
Aug 26, 2015 04:59 PM
Bull86
Aug 10, 2015 05:43 PM
