Wiring Questions ???????
Old May 7, 2010 | 04:52 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
1. im eliminating the computer controlled q-jet and distrib in my 1987 z28. there are a lot of electrical relays. i know one of them is for the electric fan but what are some of the other ones for? can i remove them or would that mess up things like the headlights and gauge cluster?
2. im switching from computer controlled HEI to a coil-in-cap HEI with a vacuum advance. i havent gotten it yet so i havent read any directions but are there any wires i should save from the old HEI for the new one?
Old May 7, 2010 | 09:20 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Wiring Questions ???????
Originally Posted by TNT_Z28
im switching from computer controlled HEI to a coil-in-cap HEI with a vacuum advance. are there any wires i should save from the old HEI for the new one?
Non computer controlled dist only needs the hot ( pink ) wire to HEI cap and white for tacho signal
Old May 8, 2010 | 11:10 PM
TNT_Z28's Avatar
thanks thats what i was thinking. as far as the relays, i removed six of the seven i found and all the wires. i tested my fan, lights, turn signals, gauges and deck. they all seem to work fine.
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
