battery dying
Old May 11, 2010 | 03:08 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
battery dying
i just got the z out for the summer and ive got a big headache of a problem which i cant quite figure out, well kinda but not really. when ever i turn the car off the battery dies in about 10 minutes (new optima red top with about ten kilometers total on it) anyway i stuck a clamp on ammeter on the big wire that goes to the starter and its drawing .53A which i think is kind of high considering the car isn't running. i compared to my pickup which is drawing almost nothing on the same wire. so what am i looking at here? starter gone? amperage seems low for something to be shorted. anyone check theirs with an ammeter while the car is sitting?
Old May 11, 2010 | 03:26 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Current Art School . . . errrrrrr . . . Current Draw
Sometimes the under-hood light does not go out so check that easy one first.
Then connect an ammeter in series with the battery.
If there is more than 50 milliamps there is excessive draw.
With everything turned off and doors closed observe the current flow.
Pull the fuses one at a time till you see the current drop.
That’s the circuit with the problem.
Happy Racing!
Spin Me This Week … I’ll Spin You Next Week
Old May 11, 2010 | 03:29 PM
Brennan's Avatar
Re: battery dying
under hood light doesn't exist since i got the new hood, ill try the fuse thing anyway but im thinking the starter is screwin with me. and is there a problem with using a clamp on meter? i should also mention that the alternator is working fine.
Old May 11, 2010 | 03:42 PM
NINÅ's Avatar
Transmission: 765R4
As long as it has a low enuff range that will work fine.
Happy Racing!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
z28joe2
Sep 28, 2015 05:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
