headlight switch bad?
my turn signals work when the parking lights are not on, When i turn the right turn signal on with the headlights it stops flashing and becomes real dim. The left turn signal is fine with the headlights on. Is this a wiring issue or a headlight switch?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: headlight switch bad?
Try replacing the turn signal bulbs both front and rear on the right side and see what happens.
not a head light switch.bad ground or ground connection in rs sockets.turn headlamps on and r signal on get out and try moving bulbs in sockets and see if starts flashing.if so you found tha bad one.also make sure rf marker in fender is working correctly can effect signal oper.
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Car: 1992 RS
Engine: Carbed 350
marker light in the fender does NOT flash with turn signal - it's a simple marker light and that's all - at least for a Camaro
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
That's strange, my 92 RS side marker lights do blink when the turn signal is actuated. In fact the two lights don't blink together, but alternate back and forth front to side. Is mine somehow special, I always thought that was normal?
Car: 1992 RS
Engine: Carbed 350
Well - maybe I'm wrong - wouldn't be the first time. But I don't remember ever seeing mine flash - now I'll have to check
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
