1983 Trans am need help , need ECM
Old May 18, 2010 | 07:24 PM
rollinchp's Avatar
Car: 1983 Pontiac Trans Am
Engine: 5.0 L CFI
Transmission: auto
My 83 trans am is bogging down when the gas pedal is pressed, its running very very lean, not getting enough fuel. Took it to a shop, they advised me it was the ECM that was malfunctioning .
I am wondering if anyone knows where or how I can get a used one , as my budget is very limited and I wanna stay on my wives good side !!! LOL
Please message me asap or call 530-514-2075 if you have one
Old May 18, 2010 | 07:27 PM
rollinchp's Avatar
Engine: 5.0 L CFI
Transmission: auto
Re: 1983 Trans am need help , need ECM
oh yea, I forgot to mention its got the crossfire injection and is automatic , and I have the OEM number
Old May 20, 2010 | 09:05 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
LOL...bad ECM is possible but there are other much more
likely causes-was the fuel pressure checked?,CEL lit?
first step is to check fuel pressure-there is no schrader
valve fitting to test pressure on the C/F,special fittings
need to be made.Inside the fuel tank is a foam-rubber
coupler hose between the pump and the steel line-
over time these can get soft and blow out,bleeding off
pressure.If the ECM is actually bad,the '84 corvette
uses the same ECM with a different chip(just use your
original chip)'82 f-bod and vette ECMs are larger but
plug in and work the same though you must use '82
chips in those.
Old May 21, 2010 | 08:01 PM
rollinchp's Avatar
Engine: 5.0 L CFI
Transmission: auto
OK well the shop has had it for a week now and has checked everything. Just about LOL. The fuel filter hasn't been changed in a while. It throws a check engine light periodically. It comes on then goes off. Very weird.
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
