Hood flap won't open ('83 Crossfire Z28)
Old May 19, 2010 | 06:50 PM
Xelios's Avatar
I hate to register on a forum simply to ask a question but it seems I'm forced to here. Not that I won't stick around though
Anyways, I recently got a 1983 Z28. But theres a few issues with it. I can't seem to get my hood flap to open. I spent about an hour looking it up on google but I can only find people asking if they're functional. I know that they're functional because I can open them with my hand and I can see an air channel so it has to work right?
Problem is, it won't while I'm driving. I've tried slamming the gas pedal, hoping that maybe air pressure will flip them open but that didnt work. I'm not the most knowledgeable about vehicles so excuse my feeble attempt at getting it to work.
Upon looking under the hood I came to find a sleeved wire going from the passenger side firewall up to the wood. Thats where I become lost though. I need to pull off the entire insulation just to get a good look under there. Its getting dark out so I won't even be able to tell what I'm looking at. So I decided to come here and ask you all about your knowledge of this issue.
The reason I'm worried about this is because I don't want my engine starving for air. My gas mileage is pretty poor as it is, so hopefully this helps it out.
Can anybody give me a few suggestions? What to look for, what may need replacing, etc? I'd be very grateful for any piece of advice.
Oh and by the way I hope Im not posting in the wrong section. I was thinking maybe it belongs in the body section but since its electrical I put it here. Sorry if I messed up.
EDIT: Oh yeah, if you guys need pictures I can try to get them for you. I don't know the proper name for the flap but I hope you know what Im referring to.
Old May 20, 2010 | 09:10 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Hood flap won't open ('83 Crossfire Z28)
the hood flap is opened by a solenoid(basicly an electro-
magnet) when the throttle is floored-first step is to
make sure the circuit is intact-including the ground
wire from the solenoid.
Old May 20, 2010 | 11:45 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
If you happen to need a new "flap assembly" I have one for sale.
Old May 21, 2010 | 04:28 AM
Xelios's Avatar
Yeah its not opening when I floor it, not even a little bit. I'll check into testing all the grounds. Maybe clean them off a bit with a wire brush as well.
If it turns out I will, I'll send you a message. Thanks for letting me know.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
3rdgenparts
Aug 6, 2015 09:03 AM
