Fuel pump question
Old May 23, 2010 | 04:33 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Fuel pump question
I'm reassembling my fuel pump carrier assembly and had a couple quick questions. First, the pump is not perfectly aligned with the fuel line, it is a little bit crooked. Second, does that little rubber bumper go between the fuel pump and the fuel line? It fell off before I could figure it out. I attached a couple pictures, not sure how good they will show it though.
Also, I know you are supposed to replace the wiring harness, but mine looks perfectly fine. And I know I'll just mess it up when I start soldering the ground connections. Any thoughts?
Attached Thumbnails Fuel pump question-img_0142.jpg   Fuel pump question-img_0143.jpg
Old May 23, 2010 | 05:56 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Re: Fuel pump question
I'm also wondering about the white plastic disc which goes between the strainer and the pump. It seems to block a line, which I assume is the fuel return line. However, there is also a small hole a little bit up the fuel return line. The metal bracket snapped off, and it may have been covering this hole. Any issues? Need to put this together!
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
