Trouble starting
Old May 23, 2010 | 08:21 PM
TPIscreamer's Avatar
Car: 1989 Camaro RS, '85 firebird
Engine: 305 TBI, 350 TPI
Transmission: built th-700r4,T-5
Axle/Gears: 3.23 Posi, 3.55 posi
Trouble starting
I just replaced the neutral safety switch on my camaro, i started it up drove it around for a while, then came back. I haven't been able to get it started since, and now if the parking brake is off when i try to start it, i turn the key over and the brake indicator light on the dash comes on. Any Ideas?
Old May 24, 2010 | 07:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Trouble starting
I found that when I replaced my NSS, the new one's plastic tab that inserts into the shifter was slightly shorter, and popped out the next time I shifted - pop the center console cover again and make sure it's still in the slot. I had to get pliers and bend the bracket some so that the plastic tab stayed in the shifter.
If that's not the issue, then might try replacing the starter enable relay - a bad relay will allow it to start on occasion, but not always. It's usually located behind the driver kick panel, under the black goo where the hood release latch is. Most NAPA's stock them for about $10.
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
