Hey can anyone help me solve this starter problem im having
Old May 31, 2010 | 06:56 PM
TRstallion's Avatar
Car: 1990 Camaro RS V8
Engine: 305 TBI
Transmission: automatic 4-speed
Ok so heres the situation. I had removed the emission control system off my camaro and I had removed all the air tubes except one. This last one was attached to the catalytic convertor. But it was also a point where some wires connected to a ground. I was a dumass and cut those wires with scissors not realizing they were wires. but i regrounded those wires but now my car wont crank at all. I mean the fuel pump turns on when i turn the key to the on position but when i go to crank it i get nothing. Anyone got any ideas?
Old May 31, 2010 | 07:14 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Hey can anyone help me solve this starter problem im having
What colors are the wires and where were they located ?
Old May 31, 2010 | 08:02 PM
TRstallion's Avatar
Engine: 305 TBI
There are 4 black wires 2 have white stripes and they are all located on the passanger side right above the y pipe.
Old Jun 1, 2010 | 06:05 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Check to see if the wire to the starter solenoid is still connected.Might have broken it or knocked it loose while removing tube
Check to see if you have 12V on that wire when key turned to start position
Old Jun 1, 2010 | 07:53 AM
TRstallion's Avatar
Engine: 305 TBI
well i tried and it doesnt have 12v and were not getting 12v. but the only thing is we were looking through the diagram theres only one or 2 black wires in the starting diagram and i didnt see and that were black with white stripes in the diagram
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
Infested
May 22, 2018 11:56 PM
Tonyy_z
Aug 12, 2015 07:20 AM
