Neutral safety switch issues, car wont crank
Old Jun 16, 2010 | 03:29 PM
1989iroc-z's Avatar
I've tried just about everything i can think of, i've searched and searched for possible solutions and i still cant figure this out. I have an 89 iroc, 350 carbed, th350, aftermarket shifter. All the accessories on the ignition work and i get power to everything but it wont crank. when i jump all the wires on the switch and try to crank i get a wierd buzzing sound from under the dash. I figured it was the starter enabler realy and im waiting on one from the store now. any ideas as to what else it might be or what i can do to try to fix this problem???
Old Jun 16, 2010 | 03:39 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Is Not Cranky, So I Am !!!!!!
You can jump pins 1 & 5 of that relay and see if the car cranks.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old Jun 16, 2010 | 07:32 PM
1989iroc-z's Avatar
Re: Car Is Not Cranky, So I Am !!!!!!
I just tried it....spliced the two heavy wires on the nss and then jumped 1 and 5 on the relay and it cranked. Thanks for the help.
Old Jun 17, 2010 | 03:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you are not worried about VATS you can delete the relay and join the two wires together permanantly
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
TheExaminer
Aug 26, 2015 04:59 PM
NBrehm
Aug 25, 2015 11:49 PM
mizz0313
Aug 12, 2015 06:45 AM
djmarch
Aug 9, 2015 05:27 PM
