starter question
Old Jun 17, 2010 | 09:22 PM
tomtom420's Avatar
Car: 86 Grand National / 90 Formula
Engine: 3.8 V6 / Procharged 5.7tpi
Transmission: 700R4 / 700r4
Axle/Gears: 3.42's / 3.23's
starter question
Two questions, first is it necessary to put back on the little star washers to the power wires and the one purple wire on the starter?? Next is I have hedman full tube headers and the come pretty close to the starter, should i wrap the starter and wires in a heat wrap or will it be fine with the kind of heat the headers give off. Thanks
-tom
Old Jun 17, 2010 | 10:07 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: starter question
The stars are like locks--
they don't vibrate loose very often. I used them, alot of ppl use tiny lock washers. Either way, you want something that won't vibrate off.
Starter protection--
alot of ppl will swear by a heat shield or wrap, & some will say it also holds the heat in once it gets hot.
IDK, I have shorties & a mini, so far no probs.
Old Jun 18, 2010 | 12:50 AM
Drew's Avatar
The star washers do more then just act as lock washers. They bite into the adjacent hardware making a more secure electrical connection. There's no reason not to use them.
Most headers are somewhat generic. Use your best judgement, but if the exhaust is closer then about 1/2" you'll probably want to do something about it. If it's too close the insulation will burn, and the fire can spread quickly.
Old Jun 18, 2010 | 02:23 PM
tomtom420's Avatar
Thanks guys for the info.
-tom
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Cleotiz
Aug 22, 2015 01:54 PM
redmaroz
Aug 16, 2015 11:40 PM
milk
Aug 10, 2015 06:26 PM
