VATS ignition key
Old Jun 26, 2010 | 04:54 AM
zcarz's Avatar
Car: 1989 IROC 5.7
Engine: 1989 5.7 TPI
VATS ignition key
I want to get a spare set of keys for my 89 IROC with VATS. I do not live in the US but am coming over for a holiday in July (Anaheim CA) so want to get some spare keys then if I can. Do GM dealers still stock these keys or if not, are there any retailers, locksmiths or the like who might stock them?
Old Jun 26, 2010 | 05:06 AM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: VATS ignition key
G.M. dealers in my area (Toledo, Ohio) are charging around $25.00 per VATS key.....
Old Jun 26, 2010 | 08:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You can buy them online ( ships worldwide ) for $10 or both keys for $13
Check out eBay items # 370391384067 and 200478180983
You need to know what # key ( 1 of 15 possible ) you have so as to buy correct one .Being where you are you may have to measure the resistance of the pellet in the key yourself
See
https://www.thirdgen.org/vats_passkey_system
Locksmiths apparently have the keys at cheaper prices than dealership
Old Jun 26, 2010 | 09:29 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Just about any Ace Hardware store stock them and can cut them as well, about $25. Maybe True Value hardware stores also.
Old Jun 26, 2010 | 09:19 PM
Drew's Avatar
Anytime you have a hardware store cut a key, you have a good 75% chance that key isn't going to work. If you aren't bringing the car to the store so you can test them right away, save your money and go to a REAL locksmith.
Old Jun 27, 2010 | 12:01 AM
Car: 1992 RS
Engine: Carbed 350
Hmmm - I've had 5 VATS keys cut at my local ACE with no issues ever - oh well - every store is different.
Old Jun 27, 2010 | 12:04 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Most any good locksmith that has reasonable experience with auto keys will have the key blanks at a reasonable cost. If you haven't yet found out what your key resistance # is they can tell you as long as you bring the key
djmarch
May 8, 2016 11:32 AM
bbsr72
Sep 27, 2015 05:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
Racerx974
Sep 19, 2015 10:16 AM
383cam
Sep 9, 2015 06:01 AM
