help me please -with vats
Old Jun 28, 2010 | 10:13 PM
affliction1's Avatar
Car: 89 chevy camaro rs
hi im trying to put a 88 camaro steering column(no vats) in my 90 rs(has vats) but im not sure if my vats will disable my car.right now my car has a resistor so i can start it,so if i leave the resistor on and connect the ignition wires will it start up?or is there more than that?please help me
...i hate vats...
Old Jun 28, 2010 | 10:25 PM
Re: help me please -with vats
bump
Old Jun 29, 2010 | 06:58 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
As long as the VATS is getting the resistor, shouldn't be a problem.
Old Jun 29, 2010 | 07:29 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Old Jun 29, 2010 | 11:05 AM
so ill just be able to wire it all up and use a nonchiped key?
as long as the resistor is in.
Old Jun 29, 2010 | 11:25 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Yep. If it worked before, it will work now. The whole point of using the resistor is to bypass the chip in the key, which is the only part of the column that is part of that system.
Old Jun 29, 2010 | 11:34 AM
thanks bro,bought a parts car for 200$ onlything missing was door and trunk key and motor
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
