Ignition Lock Cylinder the same 89 and 88?
Old Jul 4, 2010 | 07:44 PM
OddJack's Avatar
I need to change the Ignition lock cylinder. I know 89 has the vats, but I had looped it few years ago so I dont need that. Now the question is Can I buy the cheaper older models and install it? In other words everything else is the same with the cylinder size and fitment?
Thanks,
Old Jul 4, 2010 | 08:03 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Ignition Lock Cylinder the same 89 and 88?
Should be the same. I used an 89+ cylinder in my 88.
Old Jul 4, 2010 | 08:14 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
If you installed a resistor of the correct value
then you can use a regular Ignition lock.. they are the SAME minus the VATS connections
Old Jul 10, 2010 | 04:08 PM
OddJack's Avatar
For those who will have the same question:
Older locks ( prior to 89) will fit, but it needs a little work. I had to saw the whole and make it biger for the pin that holds the cylinder. Not too hard but I suggest get the 89 with VATS even if you have disabled it.
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
ericjon262
Sep 11, 2015 06:07 PM
muttracing
Brakes
Sep 6, 2015 08:12 PM
Jlanz55
Sep 6, 2015 02:35 PM
