Which Electric Fuel Pump 2 Buy???...And How 2 Set Up???...
Car: 1983 Z-28
Engine: 5.7 L
ok i want to put an electric fuel pump on my 83 Z28...
ok so i need help on buying an electric fuel pump?...which one is should i buy?...i dont need sumthin all expensive i just need sumthin that works a its reliable...i kno by gettin an electric fuel pump i would need 2 get a fuel regulator...
where would i install the fuel pump and the fuel regulator?...would i need to block off the mechanical fuel pump?..also i have no idea on how to install this...help plz...pics will b a big help...
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Which Electric Fuel Pump 2 Buy???...And How 2 Set Up???...
whats wrong with the stock one?
Car: 1983 Z-28
Engine: 5.7 L
nuthin i just want to change up the set up...and it takes a while 4 it to turn on durnin the winter...
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You'd have to
1) remove the mechanical pump and install a block-off plate to the motor.
2) attach the electical pump at the rear of the car, according to the directions with the electric pump - they push better than pull, thus closer to the tank the better
3) You'll have to use a pipe-cutter (NOT a hack saw or any other saw as they make sparks!) to cut into the fuel line at the rear of the car, cut part of the line out, and insert the pump with 3/8 rubber fuel line and clamps, clamping the rubberr line to the stock hard line where you cut, and clamping the other ends to the fuel pump with the supplied hose barbs and clamps
3) if you get the correct pump, there wouldn't necessarily be a need for a regulator - there are many electic carb pumps available that supply 6psi or less for your carb - Napa and Carquest both carry nice ones on the shelf for about $50
4) use some of the rubber fuel line and clamps to connect the input line from the mechanical pump to the output line of the mechanical pump at the block. This is where I'd personally install a secondary small inline filter as added precaution.
Car: 1992 RS
Engine: Carbed 350
Ooops - wiring LOL - the directions with the fuel pump will explain the wiring - basically just need a hot-in-run wire to the fuel pump with the recommended inline fuse, and a ground connected anywhere to the body at the pump's mounting location.
Car: 1983 Z-28
Engine: 5.7 L
ok cool thanks...doesnt sound hard wat so ever...wats the most psi i need so i wont flood the carb...and wats the least i can run to it?...
Car: 1992 RS
Engine: Carbed 350
Max psi would be 6 - anymore is too much - otherwise depends on carb - Quads like closer to 4 or slightly under, Edelbrocks 5.5 max, Holleys I think around 5 as well.
Car: 1983 Z-28
Engine: 5.7 L
ok thanks...yea i have a quad...so just to b sure should i get a regulator?...
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
