firing problem on 1985 camaro
Old Jul 10, 2010 | 12:01 AM
shatterme18's Avatar
Car: 1985 chevy camaro
Engine: 2.8 v6
Transmission: 700r4 w/ corvette servo
i have a 1985 camaro with a 2.8 v6 and i cant get it to fire. the ignition module is good the ingition coil is good the rotor is good the wires are good the plugs are good and the dist. cap is good still aint getttin any fire anyone have any other ideas what could be wrong
Old Jul 10, 2010 | 12:27 AM
1990z28's Avatar
Car: 1990 Z28 Camaro
Re: firing problem on 1985 camaro
Are yo getting spark and are you getting fuel.
Old Jul 10, 2010 | 11:25 AM
Engine: 2.8 v6
i have fuel but i am not getting any fire at all
Old Jul 10, 2010 | 11:55 AM
1990z28's Avatar
If you got fuel and spark I would say check your timing if its off enough it wont start at all.
Old Jul 10, 2010 | 12:36 PM
Engine: 2.8 v6
that is the problem i am not gettin any spark at all and cant figure it out
Old Jul 10, 2010 | 12:40 PM
1990z28's Avatar
Ok well I would see if your getting power to your coil if you are check to see if you can jump a spark from it. If you can jump a spark from it just run down to the plug and see if you can get jump from any of them and do you have a coil on the distributor like the older ones or is it off of it like on the firewall.
Old Jul 10, 2010 | 10:58 PM
Engine: 2.8 v6
the coil is off to the side and dont get any fire or spark off of coil but the coil is good put in truck and it ran perfect
Old Jul 10, 2010 | 11:13 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Are you getting power to the coil?
Old Jul 10, 2010 | 11:16 PM
1990z28's Avatar
You could have a bad ground to the coil or just no power to it at all. It could be a simple and stupid as just one wire is screwed up or something may be hooked up wrong.
Old Jul 11, 2010 | 12:02 PM
Engine: 2.8 v6
i have power to the coil checked it and the ignition module is good checked it car have spark one day and next day nothing
Old Jul 11, 2010 | 12:33 PM
1990z28's Avatar
Check your grounds on every part of the system to the coil and to the distributor. And is your distributor working right. When I first got my Camaro my distributor was bad and made it where I got no fire but every thing else was good try that if your grounds are all good. Because if I remember right it would spin right every now and then and work and I would get spark then I would try it again and nothing. So check your grounds make sure theres no broken ground or a bad connection.
Old Jul 12, 2010 | 11:08 PM
Engine: 2.8 v6
my distributor always spins could it still be bad and how can you tell if its bad
Old Jul 12, 2010 | 11:49 PM
1990z28's Avatar
I dont know how to tell if it bad but there should be a little module on the distributor that could of gone bad. Or other things could of gone bad have you had it started recently.
Old Jul 13, 2010 | 12:14 PM
Engine: 2.8 v6
had it started about month ago until battery went dead changed batterys and car would not start at this time it had spark and figured it was bad gas bc i had fuel to the motor put stuff in gas and tried to start next day and thats when i realized i didnt have spark that time
Old Jul 13, 2010 | 06:58 PM
1990z28's Avatar
I would say look at all the wiring and make sure everything is connected right. If everything is good check for broken wires or so what.
92camaroJoe
Jul 29, 2023 07:57 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
