New powermaster Alt. makes noises normal?
Old Jul 10, 2010 | 05:35 PM
406z's Avatar
Car: 1984 Z28
Engine: 406
Transmission: 350th
Axle/Gears: 373:1
Hi, I just put on a new powermaster alternator. It is the 140 amp in the cs130 case. Before I installed it I tried to spin the alternator. It was very stiff and didn't spin unless I really twisted hard. The car with the stock l98 has some trouble starting and the alternator makes a "whirring" sound. Is that normal for break in or should I return it? It pulls 13v on my guage at idle which is betetr than the old one, but the noise and rough start up have me concerned.
Thanks in advance!
Old Jul 12, 2010 | 07:33 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: New powermaster Alt. makes noises normal?
sounds like you may have a bad bearing in the alt. give it a little more time to see if things change (doubtful though), but if its still making noise, don't miss out on your warranty and get it replaced
Old Jul 12, 2010 | 08:05 AM
Twin_Turbo's Avatar
Got the same alt, easy to spin, no noises. Something's not right. I have other powermaster alternators (the small denso styles) and they require you to pull the shaft out a little right out of the box, at least that's what they told me when mine was rubbing and making noises. Can't imagine a CS130 as having that same issue. Yours is probably bad but it never hurts to check.
Old Jul 12, 2010 | 08:24 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Mines was always quiet. Been on the car for a little over 5 years.
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
BlackBoulder
Aug 11, 2015 11:15 PM
