Need wiring advice/help
Old Jul 10, 2010 | 06:14 PM
Camaro_usmc's Avatar
Car: 91 Camaro Z28 5.0 convertible
Engine: 5.0 305 tpi
Transmission: auto
Axle/Gears: stock
I have a 1991 z28 camaro convertible with a 305 tpi. It caught fire and all the wires are fried the damage overall isn't bad but all the wiring under the dash amd interrior is shot. i am restoring it and was wondering if there are kits or like a easy way to just start over. I gate electrical and could use all the help i can get with wiring it.
Old Jul 10, 2010 | 10:39 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Need wiring advice/help
Unfortunately to my knowledge there are no reproduction harnesses. This leaves you with repairing what youve got, buying a replacement from a parts car, or building a new one from scratch. If its really that bad cannot be repaired I would hunt around on craigslist, junkyards, and even post a wanted add on this forum. If that fails then you would have to make your own and if you dont even like electrical stuff to begin with that could be a nightmarish proposal. Definitely doable all the factory schematics are available but difficult none the less.
Old Jul 10, 2010 | 11:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
See these guys.
https://www.thirdgen.org/forums/engi...90-camaro.html
https://www.thirdgen.org/forums/engi...-1992-z28.html
Much easier to install a factory original harness complete than trying to play mix and match especially if you are not hot on elec stuff
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
