good battery, good alternator not getting 14 volts.
Old Jul 13, 2010 | 10:51 AM
fortemuzikman's Avatar
I was driving my car home from work yesterday and I watched the voltage gauge drop all the way down. pulled off the road, got a jump and tested the alt. it read 11.7 volts. took the alt off and had it bench tested, and it was perfect. thinking it is a wire somewhere. does anyone have the charging system wiring diagrams, or know what it might be? seems like the car is running just off of the battery
Old Jul 13, 2010 | 12:04 PM
dariel's Avatar
Re: good battery, good alternator not getting 14 volts.
YOU SHOULD READ 14 VOLTS CAR RUNNING AND THE BATTERY NOT CONNECTED TO TEST THE ALT.
Old Jul 13, 2010 | 11:09 PM
Insolinzer's Avatar
Car: 82 Trans Am
Engine: 305 TBI
Transmission: Auto :(
Axle/Gears: Whatever is stock
I have this same problem. I'm sure mine's a short though. Perhaps yours is as well?
Old Jul 14, 2010 | 07:47 AM
Found that the fan and the alternator run on the same fuse. There was a short in one of the wires going to the alt which tripped the "fan" fuse. Replaced the wire and the fuse and now it works again.
Old Jul 14, 2010 | 10:55 AM
Insolinzer's Avatar
Car: 82 Trans Am
Engine: 305 TBI
That's good to hear!
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
justin57
Aug 20, 2015 07:05 PM
killer777
Aug 8, 2015 02:47 PM
