No tach or speedo
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
No tach or speedo
Background on the car, It's a 91 Z28 that I swapped an 88 350 and 700r4 into. All the wiring is for MAP and I'm still sorting through the hack job previous owners have done. I have a VSS plugged in and the tach used to work. Funny thing is when I bang on the dash the needles move and my voltage gauge never goes below 14 volts.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Lack Of Tack
If the needles move in the correct direction when banging it might just be a loose connection in one of the two dash connectors.
After looking at those if the problem is still there you might have a crack in the circuit board.
If youre getting ground, 12 volts, and pulses to the tach board and the tach doesnt work the electronics or needle movement is defective.
Happy Racing!
Make Noise, Turn Left, Repeat
Happy Racing!
Re: No tach or speedo
what specific places should I check, I haven't worked with a dash this new before.
Car: 92 Camaro RS, 04 Dodge RAM
Engine: 305 TPI / Hemi 5.7L
Transmission: 5 speed / 4x4 auto
Here is some reading and a diagram from a 92 that should be pretty darn close to if not exact to your setup.
rs_z28_vert
Sep 30, 2015 09:47 PM
