Finishing 305 to 350 Swap
Old Jul 16, 2010 | 03:44 PM
69442DREAMCAR's Avatar
I have almost completed the swap, both were TBI. I have had problems with the rear hatch pull down. I found a used one and installed worked fine first couple of tries then stopped working. I also have a large red wire near the heater blower motor that is not hooked up. It is hot when switch is on, and looks like it had a small bulb or some type of glass in it, it has a black rubber end that looks as though you would push into a small hole and it would seal with the rubber. Any ideas?
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
