Car won't crank - rear hatch button not working also.
Old Jul 16, 2010 | 09:06 PM
JohnLarson66's Avatar
Car: 1989 IROC-Z
Engine: 5.7
When I turn the key, I hear a click under the dash, not the hood, but in the dash. At first I thought it was the VATS, but I think it is the some sort of safety switch because I can't use the electric switch to unlatch the rear hatch.
The car is acting like it is gear. Any idea about how to test this switch or where it is at before I start taking things apart.
I am been reading online and I am going to dig out my Haynes, but if someone knows where the sensor is that stops the hatch from opening when the car is in gear, please post.
Car is 1989 Iroc-Z 350
Old Jul 16, 2010 | 09:12 PM
Twin_Turbo's Avatar
Re: Car won't crank - rear hatch button not working also.
PN switch, pull the parking brake and see if the hatch works now
Old Jul 16, 2010 | 09:50 PM
Car: 1989 IROC-Z
Engine: 5.7
I have pulled on it and once in a while the hatch will open. I did have power to the starter for a millia second. So this switch is bad. How do I overide it or replace it?
Old Jul 17, 2010 | 12:01 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Under the shifter plate - the neutral safety switch - maybe it just needs adjusted, loosen two screws and it slides forward/back. Or replace, about $30.
Old Jul 17, 2010 | 01:41 AM
Car: 1989 IROC-Z
Engine: 5.7
Will try in the morning and follow up.
Old Jul 17, 2010 | 03:53 AM
Twin_Turbo's Avatar
Do not bypass the PN switch, it will allow you to open the hatch while driving. Bad idea
1992rs/ss
Jan 31, 2025 05:10 PM
Jorlain
Aug 24, 2022 05:11 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
