700r4 speedo wiring
Car: 1987 trans am
700r4 speedo wiring
hey everybody
having a problem with my speedometer. Ill start of with a little background on the car its an 87 gta that was a 5 speed and the p/o blew it out and put in a 700r4 and im trying to button up the install and run on the tranny for a while before i change it back problem is i cant get the speedometer to work at first i thought it was the speedo so i got a programmable vdo and im wondering how to hook it up correctly should it go to the vss or somewhere else any info would be greatly appreciated
thanks
thanks
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 700r4 speedo wiring
read the instructions that come with the speedo? thats a good start.
the gauge should need a switched 12v source, a switched light source, a ground, and a speedo signal. Its most likely going to have to be a buffered signal, not a raw signal straight form the sender, but all of this is should be covered in the instructions with the speedo.
under the passenderside dash, next to the computer, is a yellow box, thats the vss buffer box. There is a purple and a yellow wire, those are the 2 wires from the trans sender. there is also a green wire, thats the buffered signal to the speedo in the car now. Thats how my 86 TA is wired.
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
