Starter Relay Failing
Old Jul 18, 2010 | 08:39 AM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Transmission: 700R4 Auto
Axle/Gears: G92
I have a 1992 Z28 5.7.. The starter relay (small square relay) under the dash is constantly failing. I replaced it 3 times in the past 4 weeks. The car starts fine for a few days and then the same issue again. The starter doesn't even engage before the relay failing. Any ideas ? Could it be faulty starter ? Or may be a short somewhere?The relays are cheap , around $10, but its still a pain, never knowing if the car will start or not.
Old Jul 18, 2010 | 06:14 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Starter Relay Failing
Bypass the relay and then see if problem occurs.If it still does , you know relay is not the problem.
You can delete relay altogether if you wish.
VATS will still disable the fuel injectors so car can't be started
Old Jul 18, 2010 | 11:58 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
how would i bypass it? it has 5 terminals, how do i know which ones to connect? THANKS!
Old Jul 19, 2010 | 03:25 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by kallark
how would i bypass it? how do i know which ones to connect? THANKS!
Should be two thicker wires at relay
Join them together
Typical GM starter wiring
Old Jul 19, 2010 | 03:07 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
i'll try , thanks a lot !!!!
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
racereese
Oct 3, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
