H4 conversion question
Old Aug 2, 2010 | 01:40 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
I'm sure this has been asked a million times, but after hours of searching I can't seem to find anyone with the same problem. Here's the deal: I've installed actual HID low beams(ones with the ballast) and H4's in the high beams. When I switch to the High Beams, they are really dim and yellow. Its my understanding that they are not receiving enough wattage. I believe they are the 55/65w style. Are there relay kits to correct this? My low beams work perfectly BTW.
Old Aug 4, 2010 | 03:30 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: H4 conversion question
take a look over at this thread to double check your wiring; you may just need to switch a couple of pins around:
https://www.thirdgen.org/forums/body...eadlights.html
Old Aug 4, 2010 | 08:22 PM
mudd746's Avatar
Car: 89 IROC Convertible
Engine: 305HO
ya the pos and neg are switched around
Old Aug 6, 2010 | 10:21 AM
91_fbird's Avatar
Car: 91 Pontiac Firebird
Engine: SMall Block 350 TBI
Transmission: 5-Speed
Axle/Gears: Stock(for now)
Where did you get your HID kit from and do you have any links of the car with them installed?
Old Aug 6, 2010 | 10:43 AM
Twin_Turbo's Avatar
Actual,y all the pins are moved 1 spot clockwise for H4 when looking at the back of the bulb if this is the back of the bulb: |_| in that conf. normally it's gnd| _high beam_ |low beam
H4 = high beam| _low beam_ |gnd
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
