Check This Out!!!...Big Help WiTh Alternator Connection...Maybe Other...
Old Aug 2, 2010 | 06:23 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
ok so i have an 83 camaro...im rebuilding the engine on it...the engine is a 350 that came out of a 80's c-10 truck 1/2 tone...so while doin the rebuilt i decided to a serpentine belt setup from an 88 camaro tpi...it all bolted on but one bolt and the water pump was to big do to the previous setup so i bought a water pump for an 88 camaro 5.7 and it bolted on just rite...and now the setup is on there nice and firm...when it came down to connecting the alternator the connections werent the same......so i was tryin to figure out how to connect it and while the web for a connection that would help i came across this.....
http://www.amazon.com/s/ref=nb_sb_no....2017_1&fsc=-1
this connects to the an alternator that is for an 88 camaro and im sure other years...and it help me connect the stock wiring harness without havin to cut it up...
just thought that i would share this with u guys...idk if sum of u guys knew this already...
im not done with my build so there might b more connections that will help...i will try to keep this updated if i come across sum more...
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
383cam
Sep 9, 2015 06:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
