NO SPARK. PLEASE HELP!!!!!!!!!!!!
Old Aug 2, 2010 | 06:26 PM
shatterme18's Avatar
Car: 1985 chevy camaro
Engine: 2.8 v6
Transmission: 700r4 w/ corvette servo
I have 1989 camaro 2.8 fuel injection. i have replaced distrutor, cap, rotor, wirings, plugs, icm, and still no spark motor turns over fine but still no spark what so ever please help
Old Aug 3, 2010 | 12:18 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Got No Spark, And Also The Car Won’t Start
Using a test light (the type for testing for voltage, not a continuity tester)
connect one lead to the coil primary
(the ignition module side not the key side) and the other lead to ground.
When you try to start the car does the light pulse?
Happy Racing!
Why Did They Say I Was Speeding In The Pits? There’s No Speed Limit Sign.
Old Aug 3, 2010 | 08:19 PM
Engine: 2.8 v6
Re: Got No Spark, And Also The Car Won’t Start
i am not sure which set your are talking about the four wires that plug into icm or just the two wires that plug into the icm i tested both sets and i have power on the set with just two wires together but nothin on the set of four wires together
Old Aug 4, 2010 | 08:43 AM
NINÅ's Avatar
Transmission: 765R4
I’m not referring to the pickup coil, I’m referring to the ignition coil.
Do the test on that one.
Happy Racing!
I’ve NEVER Hit The Wall! - The Safer Barrier Prevented It
MM2Robinson
Oct 1, 2017 09:16 AM
justin57
Aug 20, 2015 07:05 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
Grumpy
16
Feb 11, 2002 05:20 PM
Bort62
Dec 10, 2001 06:01 PM
