84 berlinetta pulse type headlight switch
Old Aug 6, 2010 | 12:56 AM
zbo2's Avatar
a friend just gota 84 berlinetta and the headlight switch is bad. it's a pushbutton type switch that has the highbeam switch incorporated into it. does anybody know where to get that switch.......all the parts houses don't list it.
thanks
Old Aug 6, 2010 | 05:29 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: 84 berlinetta pulse type headlight switch
good luck. try ebay. i just got rid of a berly cuz so hard to get parts for it. and wen gauge cluster goes out he will know what i mean.
Old Aug 6, 2010 | 07:19 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Try member John in RI
Old Aug 9, 2010 | 11:26 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
E-Z 2 Get
Is this the part you need?:
(colors might vary)
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Old Aug 9, 2010 | 01:17 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You may be able to fix it depending on what's wrong with it. I did an easy fix on the other pod and it works great.
https://www.thirdgen.org/forums/post...21-post14.html
Old Aug 10, 2010 | 06:22 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a fully functinal Blinker Pod. If you still need a good pod than send me a PM with your ZIP code and I'll reply with all the details you would need to get a replacement unit.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
Stryker412
Sep 7, 2015 09:11 AM
andy74
Sep 3, 2015 08:41 AM
Slush92RS
Sep 2, 2015 08:56 PM
