Big 3 did I mess up?
Old Aug 9, 2010 | 11:09 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
I've been having charging issues so I upgraded my charge wire to 2 gauge and my battery to body ground to 2 awg also. I still have the same problems where it drops to the redline at idle and doesnt quite make it to the middle of the gauge when cruising. Will adding the engine to body ground make that big of a difference or should I look to the alternator or battery. I grounded to the body right along the frame rail where the bracket for the starter cable bolts in if that matters.
Old Aug 10, 2010 | 11:49 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Alternative Information
The dash voltmeter might not be accurate.
Have you taken measurements with a test instrument quality meter?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Aug 11, 2010 | 09:54 AM
tr6guy's Avatar
Car: '72 Triumph TR6, '85 Camaro
Engine: 2.8 V6
Re: Big 3 did I mess up?
I agree with NINA's advice. If the dash voltmeter is correct however, it sounds like you've got a bad diode in the rectifier assembly of the alternator.
F-body-fan
Jan 12, 2023 01:49 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
