No power to fuel pump
Old Aug 14, 2010 | 04:38 PM
91t5fbody's Avatar
I have a 91 rs with 305 tbi and have no power to the fuel pump the fuel pump fuse was blown and i replaced it and changed the relay and still nothing the orange wire coming out of the fuse holder beside the battery has good reading around 12.5 or 12 cant quiet remember but its good and I have no power to the grey going onto the pump checked and replaced all fuse in fuse box, any and all help would be great, Thanks in advance.
Old Aug 14, 2010 | 06:31 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: No power to fuel pump
Is the engine turning over at all? Is everything else normal except no fuel?
Old Aug 14, 2010 | 07:28 PM
91t5fbody's Avatar
yes it turns over and will crank if you pour fuel in the throttle body ofcourse i only pour a little in, I bought the car from a family friend that has been sitting for around 7 or so years and they parked it because the fuel pump wasnt getting any power and I thought that fuse could be the problem but I dont guess so. just trying to get some ideas of things it could be.
Old Aug 14, 2010 | 07:40 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
There's some kind of thing with the oil pressure sender that interacts with the fuel pump. There's been several threads on here discussing it, try a search. I can't tell you how it works, but I know a lot of other people can. Don't know if that helps?
Old Aug 14, 2010 | 07:47 PM
91t5fbody's Avatar
ok will do thanks I will see if I can figure something out.
Old Aug 14, 2010 | 09:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If the oil pressure sending unit is working, then the fuel pump should run off that. The OPSU is located above the oil filter. But this doesn't resolve the problem - the fuel pump should prime off the fuel pump relay. Check the relay connections again - remove the relay and connect with a wire the grey with the orange, and see if the pump runs then.
Here's wiring diags that might help:
http://www.austinthirdgen.org/index.php?pid=19
Old Aug 15, 2010 | 07:46 AM
91t5fbody's Avatar
ok will try that also as soon as I get back over there the car is at my moms as I cant have it at my apartment but I will check everything out and see what happens, Thanks for all the help so far guys.
Old Aug 15, 2010 | 07:17 PM
91t5fbody's Avatar
Ok update, I found out the fuel pump is bad I guess as I ran a wire from the positive cable to the grey wire and a wire from the negative to the black wire but still trying to figure out the reason there is no power the black and grey wires have been cut at the pump so im going to get a pump and a new connector and go from there checking everything else the relay, jump the ospu and see what happens. Thanks for all the help guys. From what ive been reading the fuel pump relay is the one with the grey wire, and the fan relay is the one with the big black with orange stripe??? correct?? just wanting to make sure I changed the right one.
Old Aug 15, 2010 | 07:36 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, the fan relay pigtail has 4 wires, a skinny brown and white, a skinny green and white, fat red one, and same size fat black w/red stripe. The other one's the fuel pump relay pigtail. The actual relays are interchangeable
Old Aug 15, 2010 | 07:41 PM
91t5fbody's Avatar
Okay I will check it out I changed the right one but I'm going to jump it at the opsu as soon as I get the pump and see what happens.
Old Aug 17, 2010 | 04:29 PM
91t5fbody's Avatar
Okay guys I dont think this is normal or I have not experienced it on any other vehicle but when you turn the engine over all the gauges climb as if the car were running all the way to the right as far as they can go fuel, oil pressure, tach all go to the right as far as they can.????
Old Aug 21, 2010 | 04:41 PM
91t5fbody's Avatar
Okay guys I got the car running today the connector going that pugs the fuel pump to the yellow connector on the pickup, the ground wasnt connecting good so I got that out of the way, the car has sat for around 8 yrs and while running the only gauge working was the volt gauge all the others were all the way to the right the tach was fuel oil were all the way to the right the temp gauge may have worked but I didnt let it run long enough as it needs a tune up and the speedometer looked to be ok, just wondering what is causing the gauges to do that and what to do to make them work??
Old Aug 22, 2010 | 06:25 PM
91t5fbody's Avatar
No idea why the gauges are not working proper guys???
Old Aug 22, 2010 | 07:01 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Often grounding out the signal wire to a gauge will cause the needle to peg all the way on. Perhaps insulation has worn through somewhere and is allowing some wires to be shorted to ground? Since you have a 91, you may want to remove the gauge cluster and check the connections and the printed circuit on the back for defects. I personally couldn't tell you what to look for, but it's an idea? Good luck
Old Aug 22, 2010 | 07:53 PM
91t5fbody's Avatar
ok I will check that out, I'm just trying to get this car up and running
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
