no runing lights or dash lights
Old Aug 14, 2010 | 06:08 PM
blackblurr_00gt's Avatar
ok iv searchd and not found anything that i can use to help me i have a 92 camaro rs 25th anv and recently the dashlights stop coming on as did the interior lights and parking lights the head lights work and so do the breaklights when the peddle is pushd down iv checkd all the fuses and the 5amp istrament fuse is good the only bad fuse i found was the acc fuse and every time i put a fuse in it it blows with the key on or off iv figurd out that my 5amp instrament fuse is not getting power if put power to it my dash lights works as do my parking lights. i am getting power to the headlight switch but it s not making to the fuse for the instrament panel and idk where to look now any help would be great.
Old Aug 14, 2010 | 06:29 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: no runing lights or dash lights
Do you mean the dome light doesn't work? How about your horn, power mirrors and door locks, third brake light, radio and lighter? Is that the fuse that blows as soon as you replace it? That happened to me. Turns out the lighters like to short out and screw up all the other stuff. If this is your case, unhook the connector on the back of the lighter and replace the fuse. If it's all OK now either replace the lighter or just dont plug it back in. The orange wire on the connector is always hot though, so make sure its insulated or not allowed to touch anything. Good luck! Don't know about the dash lights, sorry
Old Aug 14, 2010 | 07:23 PM
thnxs ill try unplugging that connector and dang it i really wish i could figure out the dash lights and running lights is there like another switch or relay that sends power to the fuse block or something of that sorts i know it dosent have the dimmer switch like the t/a and birds
Old Aug 14, 2010 | 07:33 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I know all the power for lights must run through the headlight switch. Maybe that's where the problem is?
Old Aug 14, 2010 | 07:36 PM
oh ya i knew that iv replaced the switch with a new one and it didntd do anything and all the wire in the switch are getting power well the ones that are supposd to get power but its like it cant get past the switch to the fuse block
Old Aug 14, 2010 | 07:43 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I'm sure since the headlight switch also dims the dash lights, you turned the headlight **** all the way to the right. Right?
Old Aug 14, 2010 | 07:45 PM
yes iv turnd it both directions and nothn changes
Old Aug 16, 2010 | 09:21 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Fright
You said you checked all the fuses, however do this:
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) see if you have power on both sides of the TAIL fuse when the headlight switch is in the “parking” position.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Pilotrick50
Sep 2, 2015 12:48 PM
dibella989
Sep 1, 2015 04:12 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
