NEED HELP WITH LT1 HARNESS CONVERSION
Old Aug 22, 2010 | 12:32 AM
stangeater454's Avatar
Car: S-10
Transmission: 4L60
Axle/Gears: 3:42
I am doing an lt1 swap in an older truck and could use alot of help figuring out how to get rid of all the unwanted wires and components. I will be doing away with all emission control crap, a/c,vats,etc. I also read some where that you can reprogram the pcm to do away with the maf. Not sure if that one is true though. I am hoping to find a schematic with these components deleted. I also need info on running the vss with a cable driven speedo. BTW the engine is a 95'. Any and all help would be great
Old Aug 22, 2010 | 02:37 AM
redltcamaro's Avatar
Car: 1987 LT Camaro
Engine: Empty at the moment
Transmission: thats out too
Axle/Gears: 4.11
Re: NEED HELP WITH LT1 HARNESS CONVERSION
The best thing you could probably do is get a stand alone harness. painless sells them along with larryselectricsite.com. i believe he programs proms as well
Old Aug 22, 2010 | 03:52 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by redltcamaro
The best thing you could probably do is get a stand alone harnessl
http://cgi.ebay.com/ebaymotors/1994-...Q5fAccessories
https://www.thirdgen.org/forums/ltx-...g-dummies.html
http://shbox.com/1/schematics_wiring.html
http://www.lt1swap.com/all_lt1.htm
http://lt1swap.com/95impalalt1.htm
http://h-body.org/people/projects/bu...ectronics.html
https://www.thirdgen.org/forums/ltx-...rt-finish.html
http://www.carcraft.com/howto/81518/index.html
http://shbox.com/1/harness.htm
Old Aug 22, 2010 | 04:19 PM
Car: S-10
Transmission: 4L60
Axle/Gears: 3:42
Trying to keep a low budget on this one. The Painless kit that I found was almost 1,000 bucks. With the Knowledge on this site, I would much rather do it my self. Only problem is,I know very little about wiring. New to fuel injection as well. I have built several carbed small blocks but the wiring on the old school **** was extremely simple. Paint and body work is my main profesion.
Old Aug 22, 2010 | 05:33 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
there are a few great links in that list from vetteoz above. your best thing to do is check out the LTx/LSx engine swap forum. Pocket's a wiz when it comes to this stuff and has tons of posts over there when it comes to wiring. another great place to go for your research is www.lt1swap.com
good luck!
Old Aug 22, 2010 | 06:31 PM
Car: S-10
Transmission: 4L60
Axle/Gears: 3:42
Yea,I checked out those links. They do look helpful. And your right, I've only been on this site for a few days reading different post and Pocket seems to really know his ****.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
LittleFranks
Oct 7, 2015 11:26 PM
L0tuS
Oct 4, 2015 08:07 AM
L0tuS
Sep 4, 2015 11:16 PM
