car not starting
Old Aug 22, 2010 | 06:58 AM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Transmission: 700R4 Auto
Axle/Gears: G92
car not starting
I have 1992 Z28 that does not start all the time. Every once in a while after I turn the key all the lights go on, but starter does not cranck. I thought it was the relay changed four of them, so then I thought it was the starter, swapped that too. But the issue persists. The weird thing is after I let it sit for five mins, and try again, I fires right up. Anyone had a similar issue? Help pls...
Old Aug 22, 2010 | 08:08 AM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: car not starting
Sounds like you have a vats issue. If you are still using the vats system, the pellet on the key could be worn not making good contact in the ignition lock cylinder or the contact prongs in the ignition lock cylinder could be worn or dirty. Its a common problem with our cars. Most people just bypass the key with a resistor. Lots of info on the site that tells you how to do this. I would start there.
Old Aug 22, 2010 | 03:33 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
I actually had a new key made, I'll try that first. I checked my old key , you are absolutelly correct the chip edges are all worn out. Thanks!
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
