Help!?!?! Two knock sensors?
Old Aug 21, 2010 | 12:44 AM
redltcamaro's Avatar
Car: 1987 LT Camaro
Engine: Empty at the moment
Transmission: thats out too
Axle/Gears: 4.11
Ok to make a long story short im swaping an 87 383 tpi into a 1987 2.8 v6 car.
The problem is the harness. I bought it off a guy on CL and there are a couple of issues. The biggest issue is that it looks like there are 2 knock sensors (i attached pics). I am almost positive that the 1 knock sensor is the real one. (The one circled with yellow) has a white wire and runs to the timing relay(what ever you call it lol). The Connector circled in blue which is a black wire runs to the large connector with 5 wires. On the other side of the connector the wire is green/white and is cut. Does anyone have any idea what this connector is and where i am supost to wire it to?
thanks
Old Aug 21, 2010 | 01:05 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Help!?!?! Two knock sensors?
What is the harness out of?
Several sensors/ switches use the same connector
Old Aug 21, 2010 | 01:20 AM
Twin_Turbo's Avatar
white is the knock sensor, the blue one is the pas side head fan temp switch which uses the same mushroom type connector
Old Aug 21, 2010 | 08:27 AM
Car: 1987 LT Camaro
Axle/Gears: 4.11
The Harness is out of a 87 iroc with a 5.0 tpi
Old Aug 21, 2010 | 08:28 AM
Car: 1987 LT Camaro
Axle/Gears: 4.11
Are these two connectors usually that close to one another?
Old Aug 21, 2010 | 08:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The sensors themselves are less than a foot apart.
Old Aug 21, 2010 | 09:24 AM
Car: 1987 LT Camaro
Axle/Gears: 4.11
there is also a connector that is melted that i cant seem to find on the wiring schematic . it is a two pin connector the the wires are lt blue/black and light green/white
Old Aug 21, 2010 | 05:21 PM
Car: 1987 LT Camaro
Axle/Gears: 4.11
also *back to the original question* the temp switch wire goes to a 5 wire connector and comes out green/white. that wire is cut about an inch past the connector. where is this wire suppost to connect to. Any help would be great because i am having a hard time reading these wire diagnostics thanks a lot
Old Aug 21, 2010 | 05:54 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
It goes to the fan relay and provides a ground when the switch reaches the correct temperature so that the relay switches power to the fan. On TPI dual fan setups, the switch turns on the secondary fan while the primary fan is operated by the ECM.
Old Aug 22, 2010 | 01:59 AM
Car: 1987 LT Camaro
Axle/Gears: 4.11
thanks this really helped fan harness is all ready to go. I just have one more problem there is are two wires are cut one is blue and one i believe is brown. The brown wire goes through the harness and connects to multiple brown and brown/white wires. I think this is a ground wire. but the other blue wire splices together with what looks like a ground wire. After splicing together it goes to the ecm I tracked it down to D11 on a connector going to the ecm. My question is 1) what connector is suppost to be there and 2) If that is a ground what do i ground it to I was taped up with oem tape inside the loom. Thanks again
ps i attached pics of the connector that the blue wire is going to
Attached Thumbnails Help!?!?! Two knock sensors?-photo-6-.jpg   Help!?!?! Two knock sensors?-photo-7-.jpg   Help!?!?! Two knock sensors?-photo-9-.jpg
Old Aug 22, 2010 | 04:07 PM
Car: 1987 LT Camaro
Axle/Gears: 4.11
bump
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
