dual fan relay gets hot and burns pig tail
Old Aug 31, 2010 | 10:39 PM
z91bowtie1's Avatar
Car: 91 Z28 convertible
Engine: 96 LT1 5.7
Transmission: t5 5speed
Axle/Gears: 3.73 gears
hey guys have a question about my fan relay. i have a 91 z28 convertible. i installed a 96 lt1. the problem im having is that the dual fans and i have them on all the time. the fans have been hard wired like that since i installed the lt1 only becuase the temp gets to hot and the car runs like crap. til resently one of the relays got super hot and burned the pig tail. i noticed it two days ago when i was on the highway my temp started going up when i got home one of the fans was off and the relay was shot. has this happened to anyone and what you did to fix it any help at all will be thankful. also i believe its the secondary fan
Old Aug 31, 2010 | 11:18 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Re: dual fan relay gets hot and burns pig tail
They should not be hard wired!
Old Sep 2, 2010 | 09:00 AM
Pocket's Avatar
Car: 91 Trans Am
They're not designed for continuous use. Your LT1 PCM has wires to control both fans independently and info how and where to do so is posted in the LTx/LSx forum
Old Sep 9, 2010 | 09:05 PM
z91bowtie1's Avatar
Engine: 96 LT1 5.7
hey guy thanks for the input. ok i check the hook up on the secondary relay which has a gray wire connected to the ac plug on the passenger side but i don't have the ac in the car. that gray wire i had hooked up to a ground so when i turned the key the fan was running. i unhooked the wire from the ground and ran the car till it warmed up. the car temp went passed 240 and fan did not come on. need info on where to hoook this gary wire to.
Old Sep 10, 2010 | 01:34 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
2 Hot 2 Trot
Why? Wasn’t the CTS operating correctly?
If it isn’t, fix it.
Then power one relay off of the ECM as in the stock configuration, and another relay off of the power contacts of the first relay.
Don’t use any of the connectors or relays which overheated.
Have one relay operate one fan each.
All these parts are capable of operating 24-7.
Happy Racing!
Engines Run Best Right Before They Blow Up
Old Sep 24, 2010 | 06:59 PM
z91bowtie1's Avatar
Engine: 96 LT1 5.7
Thanks everyone for your help. i looked over my wiring and the secoundry fan was not hooked up right so i hooked it up to the c100 green and white wire. i run the car and the fan kicks on when it gets hot.
my86bird
Oct 23, 2015 12:20 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
