Aux Power Source For Hardwired Radar Detector?
Old Sep 5, 2010 | 12:29 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
This morning I got an itch to get my radar detector working in the camaro. My factor lighter socket does not work properly with the connector. However, it does work so I am not taking the lazy way. I hate to see wires running out of there anyway.
I am going to be putting the radar detector on the dash. I lost the suction cup to mount it on the windshield. I have already spliced the original cable that hooks into the radar detector and it only has a positive and a negative. I'm ready to roll as soon as I get an answer...
1. I was thinking about just splicing into the lighter socket positive and negative. Is there going to be an issue there?
2. If adding the ends to the fuse box is a better approach, which fuse should I tie it into?
This is where I am right now....
Old Sep 5, 2010 | 07:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Aux Power Source For Hardwired Radar Detector?
In the fuse box, you'll see an empty slot with an arrow pointiing to it, and "RADIO" will be printed at the arrowhead. You can crimp a standard 1/4 spade connector on your pos wire and stick it in the slot. Then just ground the neg wire anywhere. This sonnection will only get power when the radio gets power.
Frozer!!!
Jan 19, 2024 04:55 PM
92GTA
Apr 9, 2016 07:39 AM
gta90
Sep 15, 2015 04:00 PM
Chuck84TA
Aug 27, 2015 11:14 AM
sailtexas186548
Aug 24, 2015 10:11 PM
