resistors
Old Sep 5, 2010 | 04:50 PM
overboost07's Avatar
Car: 1988 pontiac trans am gta
Engine: 305 tpi
Axle/Gears: factory
resistors
are these the resistors i need to bypass vats? http://www.eaudiocenter.com/product.php?productid=17883 it doesnt give the values, i lost my keys and already installed a new ignition and need the resistors to bypass vats.
Old Sep 5, 2010 | 06:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: resistors
You'll have to find the right resistor for YOUR car - there are 15 possible values - it's hard to do without the original key. You'll have to test each one, until you find the correct one. https://www.thirdgen.org/vats
Unbelievable how many folks don't make copies of their keys!
Old Sep 5, 2010 | 08:49 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: resistors
Your key would have been one of these values. One of the values in this table should work for you https://www.thirdgen.org/vats_passkey_system
Old Sep 5, 2010 | 10:54 PM
Engine: 305 tpi
Axle/Gears: factory
Re: resistors
sorry forgot t add the link in the first post, would this be easier than the resistors? http://www.amazon.com/Crimestopper-P.../dp/B000VUGZ2G
Old Sep 7, 2010 | 03:34 PM
Engine: 305 tpi
Axle/Gears: factory
Re: resistors
Old Sep 7, 2010 | 05:35 PM
Car: 1992 RS
Engine: Carbed 350
Re: resistors
You've been helped. You've been given the instructions on how to bypass, you've been given the list of possible resistor values, and you've been told that without the key, you'll have to test each one until you find the right one. All that's left is for YOU to go to radio shack, buy the resistors, and test each one until you get the right one that enables the car to start. There's no more help we can provide.
Old Sep 7, 2010 | 06:19 PM
Engine: 305 tpi
Axle/Gears: factory
Re: resistors
yea i know all about the resistors i wanted to know if the bypass box i linked would work easier, if so ill just buy it rather then the resistors. thats what i needed help on.
Old Sep 15, 2010 | 07:25 AM
Engine: 305 tpi
Axle/Gears: factory
Re: resistors
ttt
Old Sep 15, 2010 | 01:46 PM
Drew's Avatar
Re: resistors
Contact the manufacturer and find out.
http://ifar.ca/en/support/contact.html
Elephantismo
Feb 13, 2019 12:51 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
studebaker60
Sep 7, 2015 12:36 PM
greenyone
Aug 29, 2015 11:08 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
